Hey peeps I’ve got a 8 year old craftsman power washer with on off switch easy start with the Briggs 7.75 engine. I replaced the carb today and was wondering if the arms on the carb are oriented the right way? It started the first time for about 2 mins ran rough and died. Now it won’t start. New plug also installed. What are your thoughts?
The last few years I had to use staring fluid to get it to run. Decided to change the needle valve thinking that was it. It worked a few times then started having the same issue. It gets ran 4-5 times a year and I drain the gas out of the tank and run it dry.
