After my experience with Castrol Syntec darkening up my engine recently I decided to throw 3 different oils on my BBQ in small aluminum ashtrays.
I put 2 teaspoons each of Redline 10w-30, Castrol Syntec 5w-40 BC , and Mobil1 10w-30. I got the temps up to 600 degrees F before shutting it down as they started smoking a bit. Each sample had the same volume and were exposed to even temps.
Only able to note a few things. Castrol 5w-40 bubbled the most, seemed to be boiling, followed by Mobil1, and Redline bubbled the least. Redline darkened the most , followed by Mobil1 and Castrol darkened the least. Castrol and Mobil1 seemed to loose the most volume, Redline very little change. Castrol and Mobil1 left some residue on the upper edges of the containers, likely where they boiled off, almost varnish like. Redline seems to have left the least deposits, but I will have to take a closer look at them when they cool off.
Overall, didn't really reveal much, Redline seemed to hold up the best from an overall perspective , though it was a lot more darker in colour. Hope to see a bit more when they cool down and I can slosh the oil around a bit in the containers and see if any deposits formed on the bottom.
