Hi guys,
I have a 2003 Diamante with a 5 speed auto transmission.
While towing a heavy load, it went into limp mode.
After that it drove ok for about 20 miles, then started going into limp mode each time I drive it,
Limp mode would kick in while reaching 30ish mph at first, but now it goes into limp mode at anything between 15 and 30mph.
It goes into limp mode regardless of what gear it's in.
I have reset the TCM, swapped the TCM relay, checked and cleaned all connectors.
I have drained the ATF and checked for metal debris, including on the magnetic sump plug. All clear.
I have extracted these error codes:
42 Short Solenoid No. 1 Circuit
43 Open Solenoid No. 2 Circuit
Two solenoids going off at the same time seems unlikely.
Anyone know what it could be?
