Yes trans has thermostat.Are you having cooling issues? These transmissions are thermostatically controlled.
I haven't towed anything with the truck, therefore no cooling issues.
However, towing 8000lbs in the middle of July...
Florida is flat.Was it not rated to tow that weight?
Isn't Florida a really flat state?
Guessing you are doing overkill here...and introducing leak paths IMHO.
This has been discussed over and over again in some of the F-150 forums and the general consensus there is to not use an aftermarket cooler but if you really think that you need a bigger cooler then use one of the larger ones made (by Ford) for the F-150s that come with the HD Towing package. IIRC Ford makes two, four and six tube model coolers and they're all interchangeable and they all fit in the same location in front of the radiator and they all fit into the same brackets. Most F150s owners are satisfied that the coolers that come on their trucks are adequate unless they're doing some VERY severe towing.2012 f150 5.0 coyote v8
Currently only has trans cooler inside the radiator tank.
I could add a small cooler inline with factory.
Or I could eliminate the factory cooler and only run with this.
Suggestions? What do you think?
That is pretty much maxed out for that truck for that year.Was it not rated to tow that weight?
Wouldn’t we need to know both wheelbase and gearset to know where the OP is on that chart?That's too much trailer for that truck-regardless of what the guides might say.
CorrectThat is pretty much maxed out for that truck for that year.
No. That's too much trailer.Wouldn’t we need to know both wheelbase and gearset to know where the OP is on that chart?
If there is an OE option the fit will generally be better and easier so is a good bet. Nothing against the aftermarket ones but an OE purpose built one should suffice.This has been discussed over and over again in some of the F-150 forums and the general consensus there is to not use an aftermarket cooler but if you really think that you need a bigger cooler then use one of the larger ones made (by Ford) for the F-150s that come with the HD Towing package. IIRC Ford makes two, four and six tube model coolers and they're all interchangeable and they all fit in the same location in front of the radiator and they all fit into the same brackets. Most F150s owners are satisfied that the coolers that come on their trucks are adequate unless they're doing some VERY severe towing.
I'm pretty certain that some of the OBD monitors will report the transmission fluid temperature. I would mount one of those and see what temperatures you're encountering before replacing the OEM cooler.
