Transmission Change
PEARL River la
I checked fluid In Caravan with 28k and fluid level was full. Fluid was between red and clear so question is should I go ahead with changing at 30k? Manual states 120k for first change but I plan on keeping it as I do about 6k a year.
If you're worried, I would just do a quick drain and fill.
Not really worried as I normally change at 30k but this vehicle has synthetic in it. I probably could go to 60k but I don't want to replace the transmission as others stated problem started.
I did the first suck out and replace on the wife’s 2014 T&C just before 80k. Van still runs great and the engine and transmission will outlast the body in the Midwest IMO. Do what makes you comfortable.
Just my $0.02
