I was noticing a lot of movement in the transfer case shifter on my 2002 Xterra. Motor mounts were solid so it had to be the transmission mount, right? I pulled the skid plate to check and found this... Thought it was interesting enough to share. Talked to a friend who works at Nissan and he said they used to replace them under warranty occasionally.
Luckily this transmission was used in the 2wd version as well as the 300ZX so the extension housing (where the bracket is) is removable. Got a new one coming in but not looking forward to dropping the T-case. And the amsoil ATF in there only has 10k on it... oh well.
New to me part is on the way:
