I have a 2002 Ford Escape for which the factory spec fluid is 80w90 GL5 in both the rear diff and transfer case.
I know I can go to fully-synth 75w90 for the diff, but can I also use it in the TC? Logic suggests yes, if the factory spec oil for the TC is the same as for the diff then it should be no problem.
And of course, I have no guarantee that it's always been filled with the factory-spec fluid up till now anyway.
