I bought five quarts of Mercon SP fluid for a friends 2008 sport trac. It has the six speed auto (6r60)
From what I have seen, you must fill from the dipstick on the bottomside of the trans.
My plan is to drain using my oil extractor and then fill using a pump from the dipstick hole.
Question: If I drain while the truck if off (so I don't burn myself on the exhaust) will I be able to refill the fluid I took out? I am worried the system will drain the remainder of the fluid from say, the cooler, and I won't be able to refill.
I googled and got a bunch of "take it to the dealer" answers.
