- Joined
- Nov 23, 2021
- Messages
- 392
I am looking to get a spare tire and rim for my EZ Loader boat trailer. Are all rims the same bolt pattern for this application?
For the love of god no, TSC is so much more expensive. You can get decent trailer tire/wheel combos on Amazon for far less, I just picked up these ones for my new jetski trailer.Check Tractor Supply.
You're gonna want a galvanized wheel. I have 3 EZ load trailers and they all have 5x4.5 bolt patters...but not sure every trailer they ever made was like thatI am looking to get a spare tire and rim for my EZ Loader boat trailer. Are all rims the same bolt pattern for this application?
They change when you get to higher load capacities.You're gonna want a galvanized wheel. I have 3 EZ load trailers and they all have 5x4.5 bolt patters...but not sure every trailer they ever made was like that
Unfortunately there are pretty much zero radials sold in 4.8/4.00-r8, ended up with the ecotrail ST bias plys premounted on Amazon. They seem pretty decent however and I got ones rated for 81mph. The Carlisle ones I saw in that size were only rated for 62mph or something like that. Make sure you pay attention to the speed rating, lots of trailer tires are only rated for 60ish mph.Try Eastern Marine, they sell pre-mounted tires on galvanized rims. You will have either a 5 lug 5 on 4.5" pattern, or the 6 lug 6 on 5.5" pattern, these are the most common, though there are other sizes, measure first.
As far as bias vs radial, well, I'd take a good bias tire over a cheap radial, when radial tires fail the steel belts can cause a lot of damage. Bias are good for lower speeds, rough unimproved boat ramps, they have thicker sidewalls than radials. If you do a lot of high speed driving then yes radials are better because they don't heat up as much as bias tires but do not buy cheap ones, the only ones I'd buy now are Goodyear Endurance made in USA.
How fast do you plan on going towing your boat? It's not a race.Unfortunately there are pretty much zero radials sold in 4.8/4.00-r8, ended up with the ecotrail ST bias plys premounted on Amazon. They seem pretty decent however and I got ones rated for 81mph. The Carlisle ones I saw in that size were only rated for 62mph or something like that. Make sure you pay attention to the speed rating, lots of trailer tires are only rated for 60ish mph.
Normal highway speeds? Jetskis aren't very heavy, I'm looking at a combined weight of the trailer and pwc of about 1000lb fully loaded with gas etc. Being able to do 70-75 without worrying about tires exploding would be niceHow fast do you plan on going towing your boat? It's not a race.
I usually look for higher load rated tires when shopping the the small ones. I agree, out on the highway 70-75 mph is not out of the norm.Normal highway speeds? Jetskis aren't very heavy, I'm looking at a combined weight of the trailer and pwc of about 1000lb fully loaded with gas etc. Being able to do 70-75 without worrying about tires exploding would be nice
Rural King as well, or the other regional farm stores.Academy Sporting Goods used to sell trailer tires and wheels. If you have one of them in your area it might be worth a look.
