If you want an extreme example of how much difference a tranny can make, check out a '92 Geo Metro 1.0L:quote:
Originally posted by Winston:
But we are talking a 3 mpg difference on the highway between the two cars. I dont think tires, tranny, electric steering, and 100rpm could account for 3mpg. IMHO.
3 spd auto: 36/39mpg
5 spd manual: 46/50mpg
Because of the inefficiency of that auto, the manual gets over 25% better mileage. A more efficient automatic, probably even one with 3 speeds (and a lockup TC), could match the economy of the 5spd.
It's common to assume as much as 25% drivetrain loss on an automatic. There's a lot of room for differences there. You could probably even change it more than 3mpg on the EPA test just by changing shift mapping though; getting into high gears quicker or holding shifts longer. GM incorporates a solenoid that prevents you from being able to shift to second on the Tremec 6spd under moderate acceleration, just to improve EPA fuel economy numbers. It must make a significant difference for them to not only spend the time and money, but also **** drivers off that have to use it. Luckily, it's easy to disable.
As for the other things: car companies haven't gone to electric steering on some vehicles because it feels better, and they're definitely not running 215's on the Avalon because it performs or handles better. These things add up!
Car and Driver publishes drag area. I've got lots of back issues!quote:
RPN, where are you getting the "drag area" numbers?
For anyone that's unfamiliar with the term; it's just frontal area multiplied by drag coefficient.
