Wheel size, PCD, offset, and other specifications such as bolt pattern, thread size (THD), center bore (CB), trim levels for 2008 Toyota Tacoma. Wheel and tire fitment data. Original equipment and alternative options.
Before you just go “biggest,” what’s the plan? Will there be a lift? Will there be a re-gear? You’ll lose acceleration and you’ll end up with more chassis upset from unsprung weight over cracks and bumps over 40mph. Sometimes “biggest” looks a little off when it fills the wheel well to the max without a lift. Aesthetically, choosing an offset which pokes them outward a little looks good, though too much starts to mess with steering feel.
you don’t have to have all the answers, but this is a good place to work though some of those thoughts if you aren’t sure.
