Hi everyone,
I am about to embark on a major overhaul of the cooling system and timing chain set up in my 2006 Nissan Xterra (4.0 V6). For the past ten or so years I have run the Zerex Asian Pink coolant in the Xterra without any issues. I chose to run the pink because I also own two Toyota's and it was just easier for everything to use the same coolant.
Now that I will be replacing every component of the cooling system including hoses, should I switch to the Zerex blue coolant or is the Zerex pink fine? What are the differences between the pink and blue coolants?
Thank you,
Zack
Thank you,
Zack
