Toyota Oil Filter Question...
Houston,TX
Went to a Lexus dealership to get a replacement 90915-yzza1 oil filter( 02 Camry 2.4 l). They gave me a 90915-yzzf1 as a replacement. Computer said this was the correct replacement. Anybody have the specs or camparo for this filter? I go to Lexus for Toyota parts because I get the parts for free. A "search" never really compared these two specific filters... Thanks.
2RZE engine or 2AZFE?
Here's the only full flow that I could find under the 90915- notation under Donaldson
P502015
Representative Image
SPIN-ON LUBE FULL FLOW
Application Details
View Product Line Drawing
Lube Filters Product Attributes
A - OD (Inches): 2.56
B - Thread Size (Inches): 3/4-16
C - Length (Inches): 2.8
D - Gasket OD (Inches): 2.46
E - Gasket ID (Inches): 1.94
Relief Valve Setting (PSI): 11-17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: TOYOTA 90915-03001,
Primary Application 2: 90915-10001
Application Note: Replaces P550534
Now the P550534 is obsolete and both x'ref to Wix 51394
Now in Wix, both of your numbers appear to x'ref to a 51396
the 51396
Part Number: 51396
UPC Number: 765809513969
Principal Application: GM Vehicles (99-05), Geo (89-92), Toyota (88-08), Various Ford-New Holland Tractors, Suzuki (96-08), Suzuki Marine Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 400
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Part Number: 51394
UPC Number: 765809513945
Principal Application: GM (85-08), Daihatsu (88-92), Infiniti (91-96), Kawasaki Mules, Nissan (91-95), Toyota (80-08), Scion (04-08), Atlas-Copco, Briggs&Stratton, Cub Cadet, Generac, John Deere, Kubota, New Holland
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Thread Size: 3/4-16
Gasket Diameters
Thanks for all the info. Gary: It's a 2AZ engine. The bypass valve pressure looks different on the Wix stuff. Gregory: That table showed another filter thats been changed for another Toyota we have.
