Dexcool is ethylene glycol based, but some of the rest of the chemistry is different.quote:
Originally posted by robnitro:
Dexcool is not ethylene glycol based I believe.
I think the Toyota Red coolant is similar to this 50/50 premixed rotella ELC coolant I use in my honda. It is red and ethylene glycol, but made for trucks' extended service.
Those last 2 items are what make it different from regular EG fluids. The name for coolants with these types of adds are called OAT for Organic Acid Technology. You have to be rather careful when using in older systems because they usually eat lead solder and clog things up pretty quick. They also are not very tolerant to ingressed air in the cooling system such as can happen with cavitation.quote:
Originally posted by XS650:
[Dexcool is ethylene glycol based, but some of the rest of the chemistry is different.
Ethylene glycol
Diethylene glycol
Sodium 2-ethyl hexanoate
Sodium neodecanoate
Thats easy, the coolant tastes betterquote:
Originally posted by Spector:
the real problem with the Toyota red is that it is red and mimics PS fluid or tranny fluid. In my case, I have a leak and still trying to confirm if PS or coolant, slightly diff shade but a pain. Green is so nice to see if a leak occurs.
I think comments about Dexcool eating lead solder are myths and unsuported. I've specifically asked different engineers at GDI (aftermarket radiator company) and Texaco about Dexcool and lead solder in older heating cores and they all deny that it is any issue. I guess only time will tell.quote:
Considering how well the Toyota coolant works and the problems people are having with other coolants and switching coolants, why switch?quote:
Originally posted by Lance:
I have a 1997 Camry 2.2 about to hit 120K, ready for the belt and water pump change. Amsoil PG OK, or Toyota Red only?
I am running WW, RMI-25, Toyota Red, and 75% distilled water.quote:
and the obligatory question anybody used RedLine water wetter with Toyota red?
It's much less likely to get anywhere near the boiling point with a light mix, or even pure distilled water and Water Wetter. Water transfers heat MUCH better than glycol.quote:
anti freeze also raises the boiling point (good in hot climates)
