toyota/lexus cel evap problems
nyc/midland
Vehicle is a 2005 lexus gx470 with around 41,000 miles. I had this cel light pop up after some gas attendant in NJ over fill the tank by hammering the pump. I figured it was some gas cap issues and reset it last year and then ran the car some and I passed state inspections. I realized sometime after it was some other problem and figured as long as I can pass its okay. This year however I am having trouble as I can get all but 2 monitors to ok before the cel comes back on. It comes on the following morning or few hours after the car is shut off. I cannot figure out what the code is for exactly. I know it has something to do with the purge control valve. The air monitor of the emission part last year must have been fine in order for me to pass. Does anyone have any idea on how to fix the problem or drive cyle to get the air part ready? p1445 Also how does the evap monitor check run is it setup on some time schedule after car is shut of. Anyway I can bypass that check?
When he overfilled the gas went into the fuel emissions system. usually those have a charcoal canister etc.. no idea what type lexus uses.
It could be a few things, but first, do you hear the secondary air pump run when you start the engine?
This might help diagnose the code:http://st.club-lexus.ru/attach/u/ae103864.pdf Also, register on ClubLexus.com, there are a ton of people there willing to help, like myself.
There is no hard connection from the overfilling incident to today's code. Gas cap is #1, then lines and connections next. Solenoids and valves next.
First off the code that you have listed DTC P1445 SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE NO.2 BANK 2 STUCK CLOSE. Has nothing to do with the Evap System I will say that Evap codes this time of year are very hard to make run. I always seem to have issues with car when trying to road test. I can also see why this code comes on after the car sits or is off for a few hrs. The air pump runs and doesn't see a change and turns the light on.
Thanks everyone for responding, its been almost 14 months since this happened so I don't have any proof or video. I don't even know if this thing is the stuck valve or purge control. I am trying to educate myself on how the evap system works. I also noticed several tundras having similar problems. I have not noticed the secondary air pump but after the evap code is cel on the system the air part of the code is set and shows no fault. From my understanding the air part is secondary air injection portion and the evap is the purge canister and vsv? I only drove the car 350 miles since last year so I don't know why reset and drive does not work. Also does the secondary air need a certain voltage to kick in (less than 11.7 does not start the pump)? I was resetting the code by pulling the battery terminal, so on first startup it dies since it drains power for the nav system. Turning the ignition again it works fine. I know the battery is weak since it is on the original panasonic. I am going to try resetting via the obd2 scanner and then start it with a jumper to keep voltage up... is it possible to unstuck a switching valve? thanks
Link To get some car to pass NY state inspection I have driven some cars close to 70 miles and still did not have all the monitors reset. Some cars will do it in 10 miles others are like pulling teeth. So what codes are you getting? don't know if this will help you or not about drive cycles READINESS MONITOR DRIVE PATTERN PURPOSE OF THE READINESS TESTS The On-Board Diagnostic (OBD II) system is designed to monitor the performance of emission-related components and report any detected abnormalities in the form of Diagnostic Trouble Codes (DTCs). Since the various components need to be monitored during different driving conditions, the OBD II system is designed to run separate monitoring programs called Readiness Monitors. Many state Inspection and Maintenance (I/M) programs require that vehicles complete their Readiness Monitors prior to beginning an emission test. The current status of the Readiness Monitors can be seen by using the hand-held tester with version 9.0 software (or newer), or a generic OBD II scan tool. To view the Readiness Monitor status using the hand-held tester, select "Monitor Status" from the Enhanced OBD II menu. A status of "complete" indicates that the necessary conditions have been met to run the performance tests for the related Readiness Monitor. The Readiness Monitor will be reset to "incomplete" if: ECM has lost power (battery or fuse). DTCs have been cleared. The conditions for running the Readiness Monitor have not been met. In the event that any Readiness Monitor shows "incomplete", follow the appropriate Readiness Monitor Drive Pattern to activate the monitor and change the readiness status to "complete". CAUTION: Strictly observe the posted speed limits traffic laws and road conditions when performing these drive patterns. NOTE: These drive patterns represent the fastest method to satisfy all necessary conditions which allow the specific readiness monitor to complete. In the event that the drive pattern must be interrupted (possibly due to traffic conditions or other factors) the drive pattern can be resumed, and in most cases, the READINESS MONITOR will still set to "complete". Contents To ensure rapid completion of readiness monitors, avoid sudden changes in vehicle load and speed (driving up and down hills and/or sudden acceleration). CATALYST MONITOR (ACTIVE AIR-FUEL RATIO CONTROL TYPE) Preconditions The monitor will not run unless: The MIL is OFF Drive Pattern Connect a hand-held tester or OBD II scan tool to the DLC3. Turn the ignition switch to ON. Turn the tester or scan tool ON. Clear DTCs (where set). Start the engine and warm it up. Drive the vehicle at between 55 mph and 70 mph (88 km/h and 113 km/h) for at least 10 minutes . Monitor Status Check the Readiness Monitor status displayed on the tester or scan tool. If the status does not switch to COMPL (complete), extend the driving time. EVAP SYSTEM MONITOR (KEY-OFF TYPE) Preconditions The monitor will not run unless: The fuel tank is less than 90 % full. The altitude is less than 8,000 ft (2,450 m) . The vehicle is at stationary. The engine coolant temperature is between 4.4 °C and 35 °C (40 °F to 95 °F) . The intake air temperature is between 4.4 °C and 35 °C (40 °F to 95 °F) . Vehicle was driven in the city area (or on free-way) for 10 minutes or more. Monitor Conditions Turn the ignition switch to OFF and wait for 6 hours . HINT: Do not start the engine until checking Readiness Monitor status. If the engine is started, the step described above must be repeated. Monitor Status Connect a hand-held tester or OBD II scan tool to the DLC3. Turn the ignition switch to ON. Turn the tester or scan tool ON. Check the Readiness Monitor status displayed on the tester or scan tool. If the status does not switch to COMPL (complete), restart the engine, make sure that the preconditions have been met, and then perform the Monitor Conditions again. AIR-FUEL RATIO (A/F) AND OXYGEN SENSOR (HO2) MONITOR (ACTIVE AIR-FUEL RATIO CONTROL TYPE) Preconditions The monitor will not run unless: 2 minutes or more have elapsed since the engine was started. The Engine Coolant Temperature (ECT) is 75 °C (167 °F) or higher. Air-fuel ratio feedback control is performed. Fuel-cut control is performed for 8 seconds or more. Drive Pattern Connect the hand-held tester to DLC3. Turn the ignition switch to ON. Clear DTCs. Start the engine, and warm it up until the ECT reaches 75 °C (167 °F) or higher. Drive the vehicle at 55 mph (88 km/h) or more for at least 10 minutes . Change the transmission to 2nd gear. Accelerate the vehicle to 55 mph (88 km/h) or more by depressing the accelerator pedal for at least 10 seconds . Soon after performing step (7) above, release the accelerator pedal for at least 4 seconds without depressing the brake pedal, in order to execute fuel-cut control. Stop the vehicle and allow the engine to idle for 10 seconds or more. Allow the vehicle to decelerate until the vehicle speed declines to less than 6 mph (10 km/h) . Repeat steps from (7) through (10) above at least 3 times in one driving cycle. Monitor Status Check the Readiness Monitor status displayed on the tester. If the status does not switch to COMPL (complete), make sure that the preconditions have been met, and then perform steps from (5) through (11) in Drive Pattern above. OXYGEN SENSOR HEATER MONITOR Preconditions The monitor will not run unless: MIL is OFF Drive Pattern Connect the OBD II scan tool to the DLC3 to check monitor status and preconditions (refer to (a)). Start the engine and allow it to idle for 500 seconds or more. Drive the vehicle at 25 mph (40 km/h) or more for at least 2 minutes . Check the status of the readiness monitor on the scan tool display. If readiness status did not switch to complete, ensure the preconditions are met, turn the ignition off and then repeat steps (2) and (3).
