Well you guys finally got to me. Here is my first UOA.
One thing to note is that I didn't indicate to OAI, that I had poured in a 10 oz bottle of LiquiMoly MOS2 when I did the oil drain, so that explains the moly.
I am 80% sure that it was Pennzoil Platinum 5w20; there is a slight chance that it was M1 HM 5w20 (just vanilla M1, not AP/EP/AFE), but I am pretty sure the Mobil1 was poured into my Sienna. If it wasn't one, it was the other. The run was for about 6200 miles. It wouldn't be more than 100 miles lower or higher than that amount, so let's just use 6200. I promise next time to write this stuff down. I used the Wix 51348 for this one.
I have to say I'm pleased with the low wear metal results. A few things here I didn't quite expect, the sodium and base number.
One reason why I did this, is that I have been considering a 10K run (I would love to land my oil drains on the 140,000 mile mark on the odometer, 150K, etc.). The wear metals as you can see are fairly low; but what concerns me is the base number.
(1) Given that this reading is for a 6200 mile run, I'm not sure I want to take it 10,000 miles, given the base number.
(2) if not for coolant (I did 2 drain & fills early on in the OIC), what else would be contributing to the sodium? Or is that even enough to be worried about?
(3) What might the boron be from?
I'd want some clarification on these points before pushing to 10K; perhaps I need to sample it at some point in between 6 and 10K, just to be sure? On the other hand, if 10K isn't in the cards, that's ok, before doing a UOA I had lined up these two vehicles for 7K OCIs.
