A lot of shops won't touch them because if there is a problem they will get blamed.A few Lexus dealerships by me won’t do transmission service they standing by the Lifetime claim
I certainly don't. How can adding fresh fluid not be better?should we trust the Manufacturers when they claiming lifetime fluids
I totally agreeA lot of shops won't touch them because if there is a problem they will get blamed.
There you go! If you woulda changed it, it woulda gone 800,000 miles.I've been asking for data that shows that changing the Toyota lifetime ATF is beneficial for years. That it makes the transmissions last longer. So far, no data. Just opinions.
The transmission in my old RAV4 blew up at 399,900 miles. I changed out like 2 quarts of ATF in its life. People want to believe what the want to believe.
No need save the wear and tear on your back . You already did a service at 30k some debris clutch wear material is out . Now just listen to Lexus and not touch that transmission fluid EVER AGAIN EVERI am a firm believer in lifetime ATF. I change it every 30K; usually less. Time to get under the GS, I believe. Stupid straw level process...
BMW used to tout "lifetime fluids." "Lifetime" as in, "Yup, that transmission blew up at 138k miles but the fluid was original." Lifetime fluid are a marketing ploy, and not a maintenance philosophy.Toyota is correct - in their estimation the fluid should last the life of the transmission. Where our opinions diverge is how long that life is supposed to be.
Hey thanks for posting this. I am planning to do our 2019 Rav4 soon - and I was going to do it by weight / mass so you have confirmed my plan should be OK. I have a very accurate scale - so that seems to be a better way so I don't have to rely on eyeballing it because my eyeballs aren't what they used to be. I realize a shop could likely never fuss with weighting everything empty then full, etc - but I think that will make me more comfortable getting everything back perfect.When I was a Toyota tech we did change the fluid. I personally change the trans fluid in my Camry every 30,000. Instead of doing the procedure I measure what comes out and put exactly that back in. Don’t have to wait for temperature to come up and monitor on techstream. Very easy. The proper way to do it is to pull main plug, pull straw drain, put straw back in, fill, start vehicle while monitoring temp on techstream, when temp of fluid hits 104 degrees, you should start getting a stream, once it goes to a drip put plug back in done. If you measure fluid that comes out and put exactly back in what came out your good. That’s what we did at dealership. The fluid is made by Mobil and it’s not lifetime. That is a marketing scheme to keep the cost of ownership down. I have seen several that had never had the fluid changed with 200,000 miles but I wouldn’t recommend it. This is not a magic fluid lol
