In the spring, my dealer did an analysis of my oil because I was concerned about 'sludge'. I was running Pennzoil 10/30 (bulk) and it was shot at 2400 miles. The TBN was down to 0.5 and lead was high. The engine had 5.4k miles at the time and the company that analyzed it said the lead might be from the bearings seating during breakin.
I switched to Chevron Supreme 10/30 and had it analyzed at 3900 miles...a bit longer than I intended. The viscosity was down (5/30) and the TBN was 4.5 and still showing reserve additive. The lead was still high but was quite a bit lower than the lead in the first test. The lab (Blackstone) re-ran the test due to the lead as it was the only thing not reading normal.
What I'm concerned about at this point is that the lead could be indicating bearing wear that shouldn't be there. With the next change I'm going back to 3k to see if the lead drops closer to normal. Based on these tests, I'm going to continue with Chevron oil. Any comments or recommendations are appreciated. Here are the numbers...
mi on oil 3,940
mi on engine 13,055
aluminum 3
chromium 0
iron 5
copper 1
lead 54
tin 1
molybdenum 11
silicon 19
sodium 2
calcium 1606
magnesium 6
phosphorus 787
zinc 923
barium 1
nickel, manganese, silver, titanium, potassium, boron all 0
viscosity was low 56.0 (59-68)
everything else was fine.
Test in spring (different lab)
2400 mi on oil
~7500 mi on engine
copper 1
aluminum 4
chromium 0
iron 8
lead 131
molybdenum 76
potassium 1
silicon 39
calcium 2032
magnesium 9
phosphorus 875
sodium 6
zinc 992
viscosity 20w
TBN 0.5
mi on oil 3,940
mi on engine 13,055
aluminum 3
chromium 0
iron 5
copper 1
lead 54
tin 1
molybdenum 11
silicon 19
sodium 2
calcium 1606
magnesium 6
phosphorus 787
zinc 923
barium 1
2400 mi on oil
~7500 mi on engine
copper 1
aluminum 4
chromium 0
iron 8
lead 131
molybdenum 76
potassium 1
silicon 39
calcium 2032
magnesium 9
phosphorus 875
sodium 6
zinc 992
viscosity 20w
TBN 0.5
