jagdriver727
Site Donor 2021
2003 Highlander 1MZ-FE VVT-i, 292,511 mi, all factory timing components. I was surprised to see how good the belt looked. A testament to quality parts, I take back anything negative I've ever said about Toyota.
The water pump did not have long left, it was not making noise but turned quite rough by hand, bearings were shot. It had a couple months, tops. Glad I finally convinced the owner to do the job. We replaced the belt, water pump, tensioner and pulleys with OEM parts. Also did spark plugs (NGK Iridiums), PCV valve, ATF change (MaxLife), PS flush and obviously new coolant (Pentosin A1).
We've been maintaining this car for years but it's impossible to get the owner to come in on time. It had 13,500 miles, 7 months on the last oil change I did (HK conventional), dipstick was dry. I filled it with M1 HM 5W-30 this time, rear main seal was dripping but the engine was dry otherwise. Maybe the M1 will slow the leak down, if it gets worse it'll make no difference as I'd have ended up resealing the engine anyways. I've had good luck with M1 HM before so we'll see.
![[Linked Image]](https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/download/Number/23190/filename/18229FF7-20E9-42B9-B9D1-2A9E76060349.jpeg)
