Toyota 0W-20 SN_2012 Elantra_7,608 mi._51,272 mi.
Pennsylvania
These are both from the same stash of oil, wonder why the difference in the moly, but looks good, right?
Code:
TOYOTA SN 0W-20 BULK_7608 MILES TOYOTA SN 0W-20 BULK_7350 MILES
2012 HYUNDAI ELANTRA_51,272 MILES 2012 HYUNDAI ELANTRA_43,650 MILES
No oil added. Hyundai OEM filter. No oil added. Hyundai OEM filter.
Oct. 6 , 2012 sampled. Reported Oct. 29, 2012 Aug. 3, 2012 sampled. Reported Aug. 22, 2012
METALS (ppm) METALS (ppm)
Iron (Fe) 7 Iron (Fe) 12
Chromium (Cr)
Copper (Cu) 1 Copper (Cu) 1
Tin (Sn) 1 Tin (Sn) 1
Alum. (Al) 6 Alum. (Al) 7
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
__________________________________ __________________________________
CONTAMINANTS (ppm) CONTAMINANTS (ppm)
Silicon (Si) 10 Silicon (Si) 15
Sodium (Na) 1 Sodium (Na) 5
Potassium (K)
Coolant No Coolant No
ADDITIVES (ppm) ADDITIVES (ppm)
Magnesium (Mg) 27 Magnesium (Mg) 29
Calcium (Ca) 2126 Calcium (Ca) 2138
Barium (Ba)
Phosphorous (P) 671 Phosphorous (P) 725
Zinc (Zn) 818 Zinc (Zn) 802
Molybdenum (Mo) 51 Molybdenum (Mo) 135
Boron (B) 6 Boron (B) 11
CONTAMINANTS CONTAMINANTS
Water (%)
PHYSICAL TESTS PHYSICAL TESTS
Viscosity (cSt 100C) 8.2 Viscosity (cSt 100C) 7.8
PHYSICAL/CHEMICAL PHYSICAL/CHEMICAL
Base Number (MGkoh/G 3.7 Base Number (MGkoh/G) 3.8
Were the two bulk oil purchases on the same date? I wonder if moly is subject to settling out or quality control is lacking at Mobil.
Is the "bulk" version of this oil supposed to be the same as the TGMO available in quarts? I thought the SN version still had ~300ppm of Moly.
Quote:
I recd the results of the Toyota 0W20 SN Synthetic Oil VOA this morning. It is posted below:
Iron 0.7
Nickel 0.0
Chromium 0.1
Titanium 0.2
Copper 0.0
Aluminum 1.5
Tin 0.7
Silicon 5.7
Potassium 0.0
Sodium 1.1
Boron 0.6
Barium 0.0
Calcium 2829
Magnesium 12
Molybdenum 124 Was 800
Sodium 1.1
Phosphorus 906 Was 687
Sulfur 3489 Was 3258
Zinc 910 Was 710
Visc@40C 37.38 Was 38.2
Visc@100C 8.54 Was 8.85-9.3-9.7 depending on the lab
VI 216 Was 214
TBN 6.84 wAS 7.0
There have obviously been some changes informulation from the SM formulation, specifically Moly, Zinc and Phosphorus, but it looks like the Toyota 0W20 SN formulation continues to maintain it's very high VI unlike so many other SN formulations.
Yes. I used the last of it in my wife's car and on this change I dumped in from quart bottles I had. So the next UOA I post will be from the bottles. Then back to the bulk which I just scored again.
Quote:
BTW, why no test for lead?
My bad.
Speaking of which, is it acceptable to import an image from the lab these days? I have a .pdf from WIX which, if I knew how and it is acceptable, would be so much more convenient to use.
You would have to take a screenshot of the pdf and covert it to an image file. Post the image to a photo album account online, link the photo from the account.
