TOTAL Radiator Cleaner
Reunion Island
I had done a coolant flush and rinse with tap water, then a citric acid flush (but maybe I didn't put enough power in the water). I ran on tap water for weeks, flushing here and there, but it seemed to be still dirty.
I then crossed this cheap flush, TOTAL Radiator Cleaner, approx $7
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
I've had luck using "more than one kind of soap" to rid cooling systems of dirt.
Drain and refreshments seem to be the way to go as the systems don't get that dirty.
Originally Posted by Cujet
I'm guessing you are happy with the results?
What's in the Total rad cleaner?
Happy but it didn't get rid of cooked oil deposits in tank. I'm gonna get another one, new or lighty used.
The cleaner is made with weak acid and sodium salts.
Originally Posted by PandaBear
Where do you get citric acid for low cost? The grocery store charges 25c per oz.
The grocery store here charges approx €7 per 500 grams. Roughly like 25c per ounce
