Torque wrench 1Nm to - 15 Nm
Ndx
IL
Hi Guys,
Looking for decent quality torque wrench with very low range I have 15Nm+ but nothing below and BMW has bunch of bolts in 3Nm - 6Nm range
Thank you
What exactly are you tightening with these low numbers? Unless its a transmission band or bearing preload this tool is probably the last thing you need.
For most of that stuff I just palm a very small ratchet or a ratchet handle driver if there is room. You might find the torque wrench is also too cumbersome.
This ships to use and if you just palm it and only slightly twist it wont over tighten. This is very very small.
Hazet
Even smaller.
Hazet 2
Hazet
Even smaller.
Hazet 2
Thank you Sir!
I have a 1/4 drive ratchet that is small like that. I use it for low torque stuff like Trav suggests. I cant tell which is smaller.
It's a Blackhawk made by Proto.
A smidge less than 4.5 inches.
Now I have small hands( like equal to most women).
https://www.amazon.com/Blackhawk-Pr...+by+proto&qid=1577933831&sr=8-27
The first one is about 3.5" the second one is about 2-3/4". Hazet sells replacement grips and rebuild kits for all ratchets.
I should have said ships to USA not use.
Came across newton meter in physics , but never used it in the real / outside world . Metric measurements ! :-(
