Toro Recycler personal pace TXP 159cc information?
Northern Kentucky
Anyone know where to find serial number or any identifying information about this so I can get replacement parts for it? I don't see anything outwardly visible and when looking up owners manuals there's a bunch of different ones based on serial number.
Also if anyone has any secrets for replacement parts that aren't well known I'm all ears.
It's a slightly older model but was lightly used before I got ahold of it.
I believe if you take the bag off, let the flap go down, there should be a placard near the rear discharge. Engine information will be on its cover somewhere. The most common part failure is the drive wheels which will crack inside and cause the drive gears to grind on the wheel's steel gear. They and the small drive gears need periodic lubrication or they will bind and eventually crack the wheel inside. Part # 105-3036. They are pricey.
I have a Personal Pace I bought in 2011.
It has Grease Fittings at the rear wheels. so OP should check for them.
The Personal Pace is a great mower.
It's like going for a walk thru the Park.
Edit: as far as finding any Id numbers,
The Engine AND Mower Deck will have different Serial Numbers.
Each serial number (on mine) was a Sticker.
Your Mower looks older and stickers may have come off.
I believe Serial (or Model) # on B&S engines are stamped in metal somewhere on engine.
So that would help you for engine parts.
Now you just have to find - the years they made that Deck.
When ever I purchase any 'new' item, I record important 'numbers' into Owners Manual.
That will help you for next time.
