I saw one of those last night - I think I'll keep my 99 Silhouette and avoid offset frontal collisions if I can. They are *****!
Actually not. The 3.5L was the only engine available in '05. With a full load of people and luggage, the acceleration and handling are really no different, surprisingly enough. I have the air shocks in back, so the handling may suffer a bit on models without that (they were standard on mine, though), but power should be no different.quote:
Engine was the base 3.5 V6. Plenty of pick up around town and on highway with just 2 people and a tank of fuel, but I imagine it would get slow with a full load of people and luggage.
The engine does this because the gas pedal is no longer directly linked to the throttle plate. The computer controls the plate with an electric motor based on the position of the gas pedal. One advantage to this is they can make a rev limiter that doesn't pulse the gas on and off. The computer just won't open the throttle past a certain point when you're in park or neutral. In everyday driving, throttle response is completely normal.quote:
My brother 'tried' out the rev limiter in neutral and it's quite different than when I'm used to. Put the tranny in neutral, stomp the pedal and the tach swings to 6000 and just sits there revving away. No abrupt on-off type of fuel interruption to stop the engine from revving higher.
I see 24 mpg at 70 mph average speeds, 18 around town as calculated from fuel reciepts.quote:
The onboard computer read highway fuel mileage at about 24 mpg at 60 mph, dropping to 20 or abouts at 70 mpg. I'm unsure whether that's using the US or Imperial gallon.
Hmmm, mine is nice and tight all the time even in corners. It's quite good, especially for a minivan.quote:
Ride is fairly smooth and quiet, but still has the wallowly feeling going around corners or through dips in the road.
I work for OnStar. The microphone is specifically designed to discriminate against everything except the driver's voice (the way it should be IMO). A front seat passenger would have a little bit of a hard time working the system. It would be nearly impossible for someone in the rear seat. Either way, passenger noises should not usually interrupt the driver's commands to the system. I've even driven an XLR (Caddy Corvette) with the top down and had no trouble working the voice commands. It even works surprisingly well with foreign accents. Many of my coworkers are Indian and Middle Eastern and have no trouble working it.quote:
The voice activated OnStar system is a nice touch but it can get tedious to use. We never actually used any of the functions that would have cost money, but just played around with the voice commands. You have to speak clearly and slowly and be looking towards the controls to get the best response out of the unit. I can't imagine how hard it would be to use the voice feature with a vanload of screaming kids or loud adults.
Minivans have a lot of space to fill with sound. Without a subwoofer, the factory system is not going to sound ideal in ANY minivan, no matter the manufacturer.quote:
The standard MP3 cd player worked well but the factory speakers can't handle a lot of music with heavy bass. They distort quite easily if you turn the volume up high.
Huh? There is much more stress on the bearings on the combustion sequence.quote:
When you spin a "loaded" engine to 6K rpm, the combustion processes aid in slowing the piston down before it reaches TDC (Top Dead Center).
I don’t buy this. An engine is always under load, even when “free” revving. An engine under “heavy” load is burning a lot more fuel and putting a lot more stress on the bearings. Free revving an engine to 6000rpm is much easier on an engine than loading an engine at full throttle at 6000 rpm.quote:
When you spin an unloaded engine (to 6K rpm), you take away much of the combustion processes and the piston approaches TDC with less resistance. This puts increased strain on the connecting rod bearings. The connecting rods bolts are on the back side of the rod and can stretch causing the film of oil that the rod bearings "float" on to be broken and then it's metal to metal contact (most often ending in a spun rod bearing).
Not buying this either. And engine is set up balanced without anything attached to it.quote:
The damage caused to an engine reving in neutral, to very high rpm, is vibration. The transmission and running gear help to dampen vibration and protect the engine.
Nonsense.quote:
The speed witch witch an on loaded engine can rev can also exceed the lubrications systems ability to supply oil at the needed volume when it is needed most. When you let off the acelerator the oil pressure will fall off quicker then RPM's. The rapid acceleration/deceleration of a free reving engine can also strip the oil off of the rings.
The centrifugal force on the oil in the oil channels (rods, crankshaft) goes up instantaneously with rpm forcing the oil to the bearings at higher pressure. The oil pressure likely rises extremely fast elsewhere, and in any case, there is a constant flow the lubricant to the other parts of the engine anyway. The oil pressure is also limited above a certain rpm (the oil bypass will open) -- likely before 4000 rpm. So obviously, a lower oil pressure is adequate for a higher rpm and oil pressure does not go up continuously everywhere in the engine with rpm. And it’s not like there is no oil supply -- a good oil film there already. I see no concerns here whatsoever.quote:
With no load on the engine the engine's RPM's increase faster then oil supply,
There is not no load on the engine while free revving. The engine has to run the camshafts, oil pump, water pump, power steering pump, alternator, and air conditioner pump. Not to mention the friction losses that all increase as the motor rpm increases. The rings would also undergo much more stress under full rpm and full load. I would think 6000 rpm with little load is relatively easy on the rings compared to a full load/full throttle 6000 rpm run.quote:
the rings under no load sling the oil off dureing acceleration and deceleration with no load and do not seal well, ring movement is also unpredictable under no load,
6000rpm is 6000 rpm whether under heavy load or light load -- bearings switch direction same speed in both cases at TDC.quote:
the main bearing and rod bearing are also beiing asked to switch driection faster
4000 … 5000 rpm … is = 4000 … 5000 rpm whether under heavy or light load. An engine piston still has to compress the same volume of air at 5000 rpm whether under a heavy load or light one (very slight difference because of the different fuel volume).quote:
The load that an engine is under dureing accelerationhelp to reduce the velocity of the piston and rod before they must switch directions wich takes a lot of dynamic load off of the rod bolts and main cap bolts.
