Well today I decided to take a flashlight and look under the oil cap. After the auto-rx treatments and chemical flushes the engine has looked like fresh metal under the oil cap.
Unfortunately I saw some carbon built up. I noticed it the area where oil pools and on some of the bolts. There isn't much oil curculation up where the oil cap is because it is just the valve springs/seals..
I believe it was the previous 6 month run on Castrol Syntec that caused it..
Why?
1. It was fresh carbon, that rubbed off onto a q-tip.
2. There was no existing carbon before hand.
3. Every other oil change had been 3 months or less
It was probably a bad idea, because the car sees many short trips under 3k a day. With 100% city driving, I would not run another 6 month OCI again.
Note that the PCV valve is fairly new, but the tubing is not.
The tubing being nearly impossible to replace, because of the tight location.
If your really curious what it looks like down there, I could try and take some pictures of it.
I'm wondering what I should try..
Solvent flush?
More auto-rx?
MMO for a full OCI?
HDEO oil like Duron 10w30?
Why?
Solvent flush?
More auto-rx?
MMO for a full OCI?
