Okay, I finally got back to this. It was cold, sitting for a few days. First compression test was 115. I put a few drops of oil in the cylinder and it did 120.
The spark plug was pretty darn oily. I am not very tech savvy, I'll see if I can take a photo and attach it. I don't believe that plug has been out since mid summer of 2018, which is when the valves were adjusted.
I didn't realize that you have to pull the flywheel to open up the breather.
So, I didn't do that, but the hose was perfect inside, as well as down in the hole, what I could see.
Air filters are all clean. For a tank of gas, I put in every bit of six ounces of oil to fill it back up. Today I put in half of a four cylinder can (maybe four ounces) of Restore.
It is a 31 cubic inch Briggs, 17.5 HP, I/C. Build date was March of 2004. No oil leaks anywhere, the motor stays very clean. Like I said, no visible smoke to speak of, other than a puff at start up. Runs great.
For a spark plug it has a Champion RC12YC. Would there be something better to put back in, to help resist oil and deposit build up?
Thanks again for everyone's input, I really appreciate it.
