Do you guys wrap the ribs in aluminum foil? I've read some posts on texasbbqrub forum that recommend this if you're only doing a single slab of ribs. But then it seems that if I were to do this, I might as well just toss them in the baking oven instead of on the gas grill.
Also, don't the ribs dry out if you grill them (indirect heat method) for 5-6 hours? Are you supposed to spray them with water every so often?
I foil spares sometimes,but never foil back ribs.Foiling speeds up the cooking process a little and helps get the "falling off the bone" texture, which I'm not a big fan of.It also helps provide a consistent cooking environment while in the foil.The general guideline for foiling spares is the 3-2-1 method. 3 hours in smoke, followed by 2 hours foiled and the final hour unfoiled to firm the ribs up a little. The last hour is a good time to add bbq sauce or some other finishing sauce like Texas Pepper Jelly. These times are approximate, actual cooking times depend on size of the ribs, cooking temp etc.
Foiling also helps prevent oversmoking, which is easy to do with ribs.Three hours of smoke exposure, even with a mild wood like apple is a lot.I'd say it's a safe bet that almost 100% of competition teams foil their ribs for some amount of time, as they do with pork shoulders and briskets.
