Recently bought a toaster oven to replace an old toaster that died. They're very poorly insulated, which is to be expected, and I got a little worried about using it on our laminate countertop. Then I thought that I'm sure many people using this will be using it on laminate/Formica, so no big deal. But where we've placed the toaster oven is currently on a seam. I remember when the countertops were installed, they mentioned keeping moisture away from the seams. But what about heat? I know heat rises, but it does project heat downward too. It has 3/4" legs and room for airflow underneath, but I'm wondering if I should place a thin cutting board under it or something to shield the radiant heat.
