Hello!
I need help to decide.
I'm new to the world of oils but I understand some things.
I have a 2018 Honda Civic Type R with some "bolt ons" and a remap. Power went up from 316 hp to 400 and torque from 400 Nm to 500. The last thi g I will do is to mount a water-methanol injection kit.
The OEM oil is Honda 0w-20, API SN and, I belive ACEA A5/B5 (not sure)
Some time ago I decided to change to 0w-40 (all others performance small cars use 0w-40 or 5w-40 oils), stick to API SN but go with ACEA A3/B4. In my understanding the higher SAPS and higher HTHS of A3/B4 should protect more the engine.
At this moment I have Motul 8100 X-Max 0w-40 (SN, A3/B4) in my engine.
Now I read about SN+ and SP and find that they protect more against LSPI while SP oils ar even better for protection against timing chains elongation, sludge formation and oxidation.
0w-40 is only as a SN+ oil (ACEA C3). Where I buy motor oil they have Mobil 1 ESP 0w-40 and Shell Helix Ultra 0w-40
The SP oils that starts with 0w- and I can find here (in Sweden) are 20 or 30. (also ACEA C3). They are the Castrol Edge 0w-30 and the Mobil 1 ESP 0w-30.
What should I do? Stick with 0w-40 as many other high output 2.0 engines use and buy an API SN+ oil or go down to 0w-30 (which is still of a higher viscosity than OE oil) and buy the newer SP oil? Or stay with the ACEA A3/B4 API SN oil that I use now?
Thank you!
