I have an '03 Ranger with 235 R70 15 tires.I bought a new mounted 235 R75 15 for $20 at a garage sale thinking it was the same size.[my mistake]How much difference are there in these tires?Thanks!
Dont do it, you can/will *&?%& your spider gears in your rear end if you have two different sized in height tires on it. Trying to save a buck here is a
Do not mount two different tire sizes on the same axle. I don't even like mounting two different model tires of the same nominal size on the same axle.
Will definitely screw up handling, and as posted previously, not good for differentials.
