I needed tires on my E-150 and figured as long as I'm doing it I might as well have an alignment too. A little back ground first: I had a cord separate in the right front tire which was easily felt. I took it to a buddy of mine to make sure that my front end was in good shape, basically double checking my observations. I moved the front tires to the rear and the problem moved from front to rear. Time for tires, they were old and due for replacement.
I did some shopping and got a very good price from one of the larger tire chains. I figured they were going to try and sell me something to make up some additional profit. Now the fun, its an older Ford with the Twin I-Beam suspension. The tech comes to me and says "you need ball joints". I said that’s funny it has king pins. He them starts tugging on the right front wheel and nothing is moving. I replied install the tires and forget the alignment. He said no I can still align it, he then shows me rear brakes with about 70% life on them and says they're due. At this point the tires are already off the wheels. Now the real kick in the [censored].........I have cyclone wheels and they smashed the center caps out so they could balance the tires. Then they attempt to reshape the caps. I was so [censored] I was seeing double. Fortunately I have another set of the caps or I'd be behind bars now!
I left without the alignment and the charges for the tires are in the process of dispute for the damaged center caps.
Frank D
Frank D
