Tire crashes through windshield, killing passenger
Great Lakes
Similar thing happened to a friend of mine a while back. A wheel (tire on a rim) rolled from the opposite lanes and crashed into his F150. The F150 suffered major damage, but both my friend and his passenger were OK.
01rangerxl
Site Donor 2021
Birmingham, AL
I'm guessing trailer wheel. On a tandem axle it might be possible to lose one and keep going. I doubt it would be possible to not notice a missing wheel though. A lot of people have no problem continuing on knowing they caused a wreck or hit someone.
NE,Ohio
looks odd, 6lug? is that half of a dualie wheel set? 235/85R16..
Illinois
Yep. Something like a multiple axle equipment trailer. Some have three axles.
Oregon coast
Nope, single trailer tire with electric brake drum.
Oregon coast
Someone didn't service their bearings and use a good cotter key. Likely it came off the driverside, where the rotation of the tire would loosen the nut. They should be looking for a tandem axle trailer missing a wheel/drum/hub assembly from the left side.
NE,Ohio
I didn't realize they used 32" tires on equipment trailers.. Not that I'm doubting anyone.. just seems.. big.
Mahzurrah!
I took a fatality years ago from that but it was the driver going to work whose number was up. Came off a rear driver side axle on a semi-trailer. frown
Colorado
Wonder if the wheel's owner is aware of when it came off, and what the result was. If he was from out-of-state and just passing through, he might never know.
Lakeside CA and Lake Havasu City AZ
Six lugs are used on 5200 lb. axles. Also common on those axles is torsion suspension, which is independent of the other wheel on the same side. One could come off without the driver noticing and if the load was not heavy could continue on one wheel no problem (except for the person hit by the frre wheel).
Lakeside, CA
This happened to a guy I know years back. Only the wheel was bouncing real high and landed on his roof. Blew out every window in the car and caved the roof in at freeway speed. He got out with only minor cuts from broken glass. Wasn't even his car. He was driving his friend's car after dropping him off at the airport.
e40
Wisconsin
Winner! CSI:BITOG smile
NH
I've reused cotters a few times (finally bought a cheapo HF set so I won't need to), but I don't get why this is. I've worked the pin a few times, and IMO the bearing would have to sieze in order to for the castle nut to cleanly cut through the pin. It shouldn't take much of a pin to prevent the castle from walking out.
Top of Virginia
I would tend to agree. I think the cotter pin is many times stronger than it needs to be for a normally functioning bearing. If, however, the bearing failed, I'm not sure there exists a cotter pin that size that would hold the whole works together. It probably was a wheel bearing failure OR the case of perhaps not installing a cotter pin at all...which is also possible.
Ohio
windshield crashes through passenger, killing tire passenger crashes through tire, killing windshield passenger crashes through windshield, killing tire windshield crashes through tire, killing passenger donate your body to physics!
Illinois
Well, I called it 5 minutes earlier... but whatever. I didn't have pictures.
Flatlands of Indiana
About 20 years ago on I69,I had a set of duals come at me from across the median. I saw them coming and adjusted speed as not to intercept them. Shot across my lane waaaay into the woods. Had it been at night, I would have never seen them coming.
