The real eye opener is when you end up spending 2-3 grand on all the different adaptors, and wheel weights on top of wheel balancer, you will eventually need. I found out the hard way. I'm now needing more pin plate adaptors with the oddball bolt patterns showing up now. There is no end to it. That is why tire balancing always cost more than you expect. Just spent $700 on new cones to work with the worthless plastic chrome clad wheels. It is not so much the balancer, but more about how to make it work, even with a good wheel, and tire. A horse and buggy looks pretty good sometimes.
