I want to see what my Bosch Distance Plus looks like after 5k with synthetic and stop and go.
Those filter cutters are expensive, though.
How do you guys fo it without the tool? Thanks!
Dremel is dirty.
I have a swing away can opener I removed a pin from, and it opens Purolators and will probably open a Bosch. Wont' do a WIX (that's how I know the dremel is a mess).
Sadly, you won't find anything but a clean wavy filter when you open it at that short of mileage.
Filter cutter, IMO. Most everything else is messy and if you want to see how much gunk is on the filter, a bunch of metal shavings from a grinder won't make it easier. I got mine at Summit some years back and use at every oil change to "autopsy" the filters.
Hardcore: Run your filter longer than 5K and you'll soon save enough money to buy a cutter ( : < )!
+1 on the bench grinder. Just lightly grind around the top edge of the upper rim until the can separates and then you can just pull the can right off. Practice taking the top off an empty pop can and you will see. Easy peasy. I presume everybody here already has a bench grinder.
When I was a kid many cars had filter canisters where you simply inserted a new filter element. This would make for very easy filter media inspection, although it was quite messy for filter element changes on the particular car I saw because the filter was on the bottom and you removed a long bolt from the center of the canister. This was on a Chevy small block V8, think a late 60s model.
All the newer cars are going back to cartridge filters (ie, just the filter element) ... a blast from the past.
This one isnt mine, but the one I have looks almost exactly like it. I used to use a Dremel but that took too long on the M1 filters, this is what I use now and it cuts through them like butter.
