For those who don't know, I am retired but work 2 days a week at the local airport doing grounds and building maintenance for the local flight school. We got a new tug for moving the Cessna's and Seminole's, DA40 around the two tarmacs we own. The new Tiffen Aire 730X came into the fleet early December and I just did the 50 hour service, albeit a bit late at 62 hours.
The Tiffen tug uses a John Deere lawn tractor base 730X and is equipped with a fuel injected Kawasaki 2 cylinder FD791 gasoline engine.
The hydrostatic transmission needed the fluid and filter changed. The filter was a pita to remove, and the maintenance hangar mechanics didn't have a strap wrench for me to use, so channel locks it was.
20211230_105112_resized by Ken , on Flickr
-719111095_20211230_105128_1992450_resized by Ken, on Flickr
A Wix 57103 went on and the transmission took about 8 litres of Low Viscosity J20D equivalent (Tuxton brand)
The filter thread was too big to use the filter cutter for the airplanes, so I had to use a hacksaw and aviation snips to free the filter element from the case. No ADBV in these, no bypass, not much inside,
Hope this is interesting for you guys?
