About 6 years ago I picked up a new Craftsman T2200 riding mower (built by husqvarna) to mow my 1.25 acre lot in south florida (thick grass all year). I worked the mower hard (probably harder than it was designed for).
The good - reasonably strong, could power through thick grass. It had a briggs 19HP single cyl and a 42" deck. Hydrostatic transmission on a hand lever was nice and my kids could work it where they wouldn't be able to reach the pedals. Decent cut, decent turning radius.
The bad - I went through spindles constantly - probably replaced them 3 times. After the first spindle replacement I was always fighting the deck height adjustment and never managed to get a perfectly even cut after that. Deck rusted out after a few years and I've been holding it together with sheet metal and welds. About 6 months ago I think the headgasket started to go as it would puff blue smoke frequently. I bought a head gasket to replace it but never got around to it. I added oil more frequently after the blue smoke but I guess I didn't check it often enough and time got away from me because I just threw a rod out the side of the block (my fault for not checking the oil).
So now I'm looking for a new unit with about the same specs. Looking around online, most of the mowers look identical to the one I have - deck looks the same, frames look the same, transmissions look the same. Looks like most switched to foot control on the hydrostatic which is not what I prefer but whatever. Most mowers either have a briggs 18.5 intek or a kohler of about same HP. Should I go with the briggs again? Obviously the low oil was my fault but I'd prefer something that doesn't need a head gasket after 5 years. As for the deck - any models that have a more substantial deck that won't rust out so fast or are they all the same? I'm looking at the Husqvarna YTH18542, the identical craftsman T210, and maybe a similar cub cadet at home depot (though haven't investigated their models yet). I'm partial to the husqvarna as my spare parts (spindles, blades, maybe even the old transmission, belt drive, etc) might carry over.
