This winter I will be spending some time in Michigan's U.P. near Copper Harbor/Houghton and the rest in Central Lower Michigan and I was thinking about the ultimate cold weather oil for my truck. 2009 Chevy Silverado 1500 Crew Cab 4x4 with a 6 liter engine. Lots of Hiway miles and very little trailer towing. I will use a Fram Ultra and follow the OLM to 5% oil life remaining.
Here are my 4 ideas from wild to mild:
1. 100% Redline 0w-20 HTHS of 2.9 Pour point of -76F. Yes, I know the truck was speced for 5w-30 but this oil isn't too far from being a 30 wt and this might make a very interesting UOA come spring time.
2. 50/50 blend of Redline 0w-20 & 0w-30. Should give me an HTHS of about 3 and a pour point of -76F
3. 100% Redline 0w-30. HTHS of 3.2 and the same pour point of -76F
4. Regular old M1 AFE 0w-30. HTHS of 3 and a pour point of -58F
You might ask, why the 50/50 mix of redline? Redline oils are a bit thick for grade and this was an attempt to get it near the M1 AFE levels.
Yes I know Redline oil is a bit on the pricey side but I'm OK with that.
So what are your thoughts? Which one would you pick?
