So with all of these "special esters" can I bypass the maintenance dose of auto-rx?
Why are these esters not used in any Castrol motor oils other than the German made 0w30? Or are they?quote:
Originally posted by MolaKule:
These esters were developed in German labs between approx. 1991 and 2000 and have been improved upon since then. There are two flavors of these esters, both derived from PAO olefin polymers.quote:
So these "unique" esters.... are they better than what you would encounter in Mobil 1 or other oils? Does different mean "good"
It is believed these esters are responsible for the AW and FM performance of GC wihout the inclusion of triborates and molys.
Not necessarily good, just different. With the levels of zddp and calcium, and the high viscosity PAO bases, the formulation appears to be a good one.
First off, these esters are COMPLEX (see Interesting Articles section on white papers), and very viscous esters, and have been used in industrial gear lubes for at least the last decade.quote:
So why would Castrol want to use an ester that's more expensive? Why not just use esters that are already avalible? There must be some reason for using it over the others. Are there any other specific industries that use such a thing?
You are meanquote:
Originally posted by rcy:
Nice.
Now can you do a Haiku?
quote:
I honestly don't care what GC is made of. For professionals, it's important info. For oil buffs, it's interesting but for most consumers who just want high-end oil, the mfg specs are enuff to get the nod. This is how Audi dealers are selling the BC 5w-40, it's "good enough". I am somewhere in the middle of finding it interesting, because of my backround in H&SS makes me want to know the underlaying truths about products and not really caring. Also, because I have the responsibility of caring for a lot of expensive cars, I should know what works best and is cost/effective. Anyway, the fact is that GC is imported and exclusive in a non-mailorder sort of way. I really don't care what it is made of if it works and carries the approvals that take away the burden using it "of my own volition". I only care in as much as it is interesting. One thing I have learned here and by reading ALL the primary pleadings in the Mobil v Castrol case is that "synthetic" as a chemical definition IS met by the hydrocrack process. The everyday meaning is derived from Latin suntithenai "to put together" and implies something different. The chemical reference materials state that the substance merely be "changed substantially" to be defined as undergoing " synthesis ". Castrol was right, get over it. BTW- I would snatch up any Euro oil that was locally available and latest technology!!! It just so happens it's green and smells nice, all the better. OEM fill in Audis too. I did not come here with any brand loyalties and like Castrol, but usually buy Mobil, except for GC.
I alway like to post this little linky for the nay-sayers.
http://www.castrol.com/castrol/genericarticle.do?categoryId=82916482&contentId=6005377
How much off?quote:
Originally posted by Shifter:
Note to Canadians: All grades of Castrol Syntec, including made-in-Germany 0W-30 grade, is on sale this week at Canadian Tire stores.
It's $6.36 per liter this week. Regular price is $7.49 at CT (or $7.12 at Walmart)quote:
Originally posted by BlazerLT:
How much off?quote:
