Two common narratives that I’m sure you’ve heard:
1. Some synthetics could cause deposits for some unknown reason – this is Mazda’s official line, and one that many independent rotary shops support
2. Many synthetics don’t burn easily enough, possibly accumulating and causing problems
I’m sure you’re also aware of the plethora of synthetic engine oils specifically for rotary engines, including the one Mazda sells under its own name specifically for the RX-8. And the large number of race teams (including Mazda's own), rotary tuners, and RX-8 owners that use synthetics exclusively and successfully.
Here’s my question: Could the "synthetics cause deposits" narrative have come from cases where the oil was too combustion-resistant and too dirty for the way the car was driven? In other words, might those issues have been solved by picking an cleaner-burning oil OR by driving harder?
Royal Purple quotes a range of 500º F to 1700º F for combustion temps in this car, which seems fairly plausible. The lower end of that range isn’t much higher than the flash points of some high-end synthetics. At those temps, I'd imagine those synthetics would burn, but not necessarily well, and not necessarily quickly. If they or their byproducts accumulate, they could not only burn poorly themselves, but also start to interfere with combustion of the fuel. All of that would increase deposit formation. Conventional oils might have a slightly easier time on average at those temps. Or for that matter, a semi- or full-syn with a relatively low flash point and high volatility, or really good self-cleaning, etc.
How plausible does this seem? What am I missing?
