Raise the car level...either a lift or jackstands under both ends. Find the transmission drain plug (do not remove) then find the transmission standpipe plug. Remove the standpipe plug and the ATF should be at the top of the standpipe. I've been told by Red Line that their D4 ATF is good for VW/Audi and Volvo transmissions that do not take Dexron-III.quote:
Originally posted by RH+G:
VW and Audis dont have dipsticks either. Lifetime fluidChecking them without the proper tool mskes it impossible to get a right reading
Did you check your owners manual for type of fluid Toyota says to use? My 2004 4runner V8 with the new 5speed auto uses WS ATF fluid (World Standard) it is not compatible with Type-IV ATF fluid. The new WS was introduced last August in the 4runners/Landcruisers/Lexus LX470 and GX470 and is a lifetime fluid for normal use and requires service if you tow at a 60K mile interval.quote:
Originally posted by ekpolk:
My 2003 V-6 Camry does have a trans dipstick, and it is a Type-IV fluid car.
So, does anyone know for sure, is the Type-IV a synthetic or not? I had a dealer tech tell me it was, but otherwise, I have no info to verify.
Absolutely yes, 150% certain it's a Type-IV car. It's in about six places in the manual. I used to fly jets in the Marines. I don't operate machines, including my cars, without reading, and knowing, the published manuals. . .quote:
The Amsoil won't work with the 2004 5speed automatics that use the WS ATF. I would also be real careful about using what Amsoil recommends without checking with the manufacture. I know when I had a Dodge 1ton with the 6speed manual transmission that Amsoil recommended using their 5-30 synthetic engine oil in the transmission and the manufacture said your warranty would be void if you did. I think Amsoil makes some good products but I think they get carried away with what they think some of it is capable of doing. Since their sales force is a multi-level marketing set-up they get a lot of cheerleaders pushing the product. I would use their synthetic motor oil in my engine. JMHOquote:
Originally posted by TooSlick:
Amsoil is recommending their synthetic ATF for the Toyota Type T and Type T-IV applications. If I owned a new toyota or lexus, I'd put it in ASAP ....
Tooslick
Dixie Synthetics
The infamous g-induced 'roids were less of an issue in the Prowler community than they are for the Hornet and Harrier guys. For us, no more of a problem than trench foot for a modern grunt. . .quote:
I was talking to the parts guy at the local Toyota dealership yesterday. He stated that both the Type IV and the WS ATF fluids were synthetic. Like you said I would just follow the owners manual on change interval. By the way since you were a Jet pilot, how are though hemorrhoidsSemper Fi from a Grunt.
