- Joined
- Feb 6, 2021
- Messages
- 1,410
Didn't know WD-40 attracts fish when sprayed on baitWD-40 is a godsend for people with arthritis;
https://www.blog.ohmyarthritis.com/the-many-uses-of-wd-40/
Good thing. It can soothe the pain from the 3rd degree burns when you light it!!If you spray WD40 on tobacco before you smoke it it is just like Marijuana !!
Tar on rocker panels etcWD-40 can be good for many things in a pinch if you need something and don't have anything else around. I've used it to remove adhesives and other gums and gunk that dedicated removers like Goo Gone wouldn't even touch.
Not a lot of distributor caps out there anymore, but I've used it for the same thing. Seems to be the best use for it.Several times I've gotten people's cars started in the rain by removing the distributor cap and spraying the inside of the cap with WD-40.
That hasn't happened for a while now.
Yeah OK. Used it before I’ve went to loosen a bolt, spark plug etc. never a issue. Obviously you haven’t used it much or PB BlasterIt drives me insane when I go somewhere and see someone trying to use it as a penetrating oil and then they wonder why their bolt won’t break free lol.
I prefer SiliKroil. AeroKriol with silicone. Great product (with two horrible cans that leaked at the valve stem).Aerokroil the forever king.
That’s why in it’s prime folks used it to dry out a distributor !Remember what WD stands for.... Water Displacing. Use it for that and it is fantastic. Lubricant, not so much.
I use it to soften and dissolve sticky hydraulic residue. I also use a rag soaked in the stuff to wipe down tools before putting them away.Remember what WD stands for.... Water Displacing. Use it for that and it is fantastic. Lubricant, not so much.
