Seems reasonable. I do 5000 mile changes since I drive 10-15k per year but if I didn't I'd probably do 6 month changes as well.
The engines are moderate fuel diluters by most accounts (2-5%) despit dual DI and MPI. Low annual mileage often equates to short trips, which have a tendency to increase fuel diltution.
There could be some benefit to swapping the oil out, especially at the beginning of the cold season. The 2.7L along with many ford engines uses a wet belt oil pump, and there are anecdotes that having that belt sitting in fuel-diluted oil is not good for its longevity. Freshening up the oil and the corresponding reduction in fuel diltuion after an oil change can't hurt; no guarantee it would really help either. I have yet to see data on the rate of change of fuel dilution, although I've seen one 500 mile horizon oil analysis of the factory fill that indicated 2.5% fuel dilution after that mileage and then 1.9% after 5000 miles. All this intended to say: if you can absorb the cost of a 6 month oil change, I see no problem with it, and it might help....
In piston airplanes we are told by the engine manufactuers to change the engine oil every 4 months or 50 hours of engine operation. I know they are completely different engines (can only use a 50% synthetic blend at most, and lead in the fuel), but I wonder why that is.....I'm guessing low deteregent additive packages due too high operating temps (400F cylinder heads), in turn resulting in faster oil acidity.
