- Messages
- 693
- Location
- Vancouver, BC Canada
Jawa's are Czech made motorcycles... back from the Eastern Bloc era... and they are still produced to this day (I think now owned by Mahindra)... still with a Czech Republic factory, I believe. Well, in Canada, a person can import and run a 15 year old- or older motor vehicle... without the need to be emissions or safety equipment compliant, if, however, it was made by a legitimate producer.
I have a bit of a perverse love affair with 2 strokes... and the Jawa is possibly the ONLY one out there that has a ready supply of spare parts being manufactured, to this day. On a 2 stroke, you would want to be able to find spare crankpins, big and small end bearings, conn rods, oversized pistons and OS rings, crankshaft main bearings (typically ball bearings), and crankshaft seals. All of these components are readily available for Jawa's... and cheap. And the Jawa design has changed ever so little over the years. It apparently is reasonably durable.
Now, it is NOT sophisticated. Only 4 speed gearboxes... and though they had a Czech made oil injection pump, and then latterly a Mikuni one... they NOW have none... and require premix. They have a labyrinth centre-seal and two centre-bearings. The case split line is a vertical plane... not as nice as the Suzuki T500 (which has a horiz. plane split line and bearing anti-rotation dowels). Oh, the Jawa has a fully enclosed non-o-ring chain... and I THINK they may have an automatic chain oiler... ?
So, my question is... if a person does have to run pre-mix... and for the Jawa, 32:1 is probably best (for middle crankshaft bearings longer life expectancy) - can I expect a bike running 32:1, though running a high quality synthetic, to smoke a lot?
The other bike I am considering is a Suzuki T500 (or GT500)... last made in 1977. A bunch of parts are, understandably, NLA. However, it is clear that the Suzuki has a superior crankshaft lubrication system, and is 'way more sophisticated in terms of drive-quality. But NLA parts means a whole lot of workarounds to be able to run them. This gives me pause. And they are very, very expensive!
Any ways.... your thoughts re the Jawa... and smoking?
