Originally Posted by RDY4WAR
Originally Posted by SR5
Nice post RDY4WAR,
Within cold start requirements, most engines should be quite tolerant of oil viscosity. The biggest viscosity swing they see is due to temperature, not oil grade.
M1 0W20 Viscosity = 44.8 cSt (at 40 degrees C)
GTX 15W40 Viscosity = 14.5 cSt (at 100 degrees C)
Here is the owners manual from Australia for a 2018 Camry Hybrid, it says you can use 0W16, 0W20, 5W20, 5W30, 10W30 or 15W40
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4890579/1
BTW our oil fill caps just say "oil" or show an oil can.
An important factor to consider is bearing heat. As known, higher viscosity generates more hydrodynamic friction. Imagine two bowls, one filled with water and the other with honey, and try to stir them both with a spoon. The honey is much harder to stir due to the increased friction from the higher viscosity. This is a somewhat similar concept to crank journals spinning around in high viscosity oil. A result of friction is heat. That 0w-20 oil at 40*C and ~45 cSt could produce a temperature delta through the bearings up to 80*C rise. That 15w-40 oil at 100*C and ~14.5 cSt may only produce a 10-30*C temperature delta through the bearings. While the 0w-20 is much more viscous at 40*C than the 15w-40 at 100*C, the inlet temperature is much lower to where a higher amount of friction and temperature rise can be tolerated without overheating the bearings and wiping the bearings. Put in an oil that's ~45 cSt @ 100*C sump with an 80*C temp delta, then you might have a problem.
Yeah put an oil in that is 45 cSt at 100C, and I suspect your problem will be getting it up to 100C from a cold start. Even Penrite 40-70 (called 40W70, but no real 40W cold starting standard) has a 100C viscosity of 31 cSt and a 40C viscosity of 325 cSt. I'm of the belief that the biggest problem is starting (cranking and pumping), if you can start with an oil and let it warm up gently, then you will be ok.
Sure friction will makes a thick oil run a touch warmer, but it will work and still be thicker than a thin oil running a touch cooler. But you know all this, you are an expert, my comments were more for clarification for readers new to the field.
And that, "use what is on the cap" doesn't apply to much of the world, and I think undersells the ability of an intelligent owner to read a temperature viscosity chart to use an oil suitable for their climate and application.
