Frantz was big on filter studies back in the 50s and 60s. Most of us got our start with Frantz. Frantz literature tells me that a human hair averages about 90 microns. The smallest particle visible to the human eye is about 40 microns. Fine sand is about 12 microns. Atmosperic dust is from 1 micron down to about 1 tenth micron, carbon black is around 7 or 8 100ths of 1 micron. Rod bearings, main bearings, valve stems and piston clearances are about 20 microns down to about 8 microns. Diesel fuel injector, oil ring to piston groove, cam to hydraulic lifter, push rod to lifter, rocker arm to valve stem, automatic transmission control valve to valve body clearances are between 2 microns down to about 1 tenth micron. The report came out after the Aero Frantz was certified by the FAA. Frantz got FAA certification for the Aero Frantz about 1971.
Cigarette smoke is about 1/10th of 1 micron. Cigarette smoke is mentioned because a high quality tightly wound roll of TP is rated at 1/10th micron filtration. I got started using sandwich adapters made by Frantz in the early 80s. Frantz was big on adapters. When Amsoil first came out with their bypass filter some dedicated Amsoil users wanted to use the Frantz sandwich adapters with the Amsoil filters. Your man up there said they would make the bypass filter not work. The proper filter to use with a sandwich adapter is the Frantz or Motor Guard. I like the Perma-Cool sandwich adapter better. It helps to understand sandwich adapters. Most of the people I deal with understand that a TP filter will restrict the oil flow like a clogged oil cooler. The oil must have another way of getting to the full flow filter. That would be thru the sandwich adapter relief valve. If you feel the relief valve is too small you can drill the adapter. If the sandwich adapter has no relief valve such as with a GM model the relief valve in the filter mount will open and bypass both filters. That will turn the engine into a straight bypass system like a 53 Chevy. The reason these companies like
www.jegs.com stay in business is there are a lot of gear heads out there that can handle understanding where the oil goes when the bypass filter can't supply the engine or when the oil cooler is clogged or too cold. I have some California gear heads that are installing a filter remote mount kit on their diesel pickups. The filter remote mount has four ports. Then they are using the two extra ports to hook up the Motor Guard. They are using the pressure drop thru the full flow filter to feed the Motor Guard. I do that at work on a large air compressor but haven't tried it on a engine. Some want to get the Cummins full flow filter where it is easy to get to. A bypass filter will clean better at low pressure drops. the Motor Guard is running on a 3 PSI pressure drop thru the full flow filter on the air comressor. The Motor Guard keeps the full flow filter clean so it stays at 3 PSI.
I don't want to bad mouth Amsoil users. They take care of their equipment and they buy TP filters. I know there are the ones that say if it has Amsoil written on it it is the best.
The reason I use the Perma-Cool isn't because I think it is better than the other sandwich adapters. I have been getting some that have the ports tapped too deep. If someone wants to use a sandwich adapter as only a pressure source simply drill a few holes in the adapter to eliminate any pressure drop and plug one port. Return the clean oil to the engine in the conventional way. The restrictor orifice isn't needed when you use the two port sandwich adapter because you aren't taking oil off the system. If you convert the sandwich adapter to a one port adapter you will need the restrictor orifice. It is easy with an oil pressure gauge. If the oil pressure comes up good after the installation and the Motor Guard heats up it is working. If not drill the adapter. Drill the relief too large and there won't be enough pressure drop to feed the Motor Guard. 7/32" for a large engine will work. I wouldn't drill the adapter on a small engine like my Subaru. I drilled the adapter on the Subaru 1/4". It worked but it took too long to heat up the Motor guard. On my 20 HP Kohler engine the Motor Guard depends on the spring in the sandwich adapter relief valve.That was a problem with the Frantz sandwich adapters. They sometimes didn't have enough flow thru the adapter to feed the bypass filter on a small engine. There were no springs to hold a small pressure on the bypass filter. They had to cover a large range between a lawn mower and a large V-8 engine. The Perma-Cool people say the relief valve is large enough to handle the flow. The problem might be in the real world where the engine might have some bearing wear and needs more oil flow to pressure up the engine. Then you might have someone with a worn oil pump that doesn't have enough oil pressure to open the 2 PSI relief valve in the adapter at idle. You can't base everything on ideal new engine conditions.
It is probably not a good idea to put a cut away filter where a TP filter user can see it.
Ralph
