That is the question; just had to put a new stat in my Corolla; the factory ones come with a jiggle valve, the Stant ones do not, so I drill a small hole in the flange and positioned it at 12 oclock when installing. I know the jiggle valves sort of seal when the flow goes through the thermostat, preventing overcooling. I'm curious if just a small hole will make the car not get up to temp in very cold weather. Thoughts? Who's drilled a stat and had a car in very cold weather?
Thanks
