The type moly used in Mobil 1 R
The Tropics of Antartica
I was looking at a Australian website for viscosity recommended for the Honda S2000 " 10w-30 btw - 10w-30 for some newer Toyotas as well "
and found the 1R uses Molybdenum Polysulfide Alkyl Dithiocarbamate in the formulation .
This a a different moly than I've seen or is the name just in a full listing here ? Could this be the same moly used in the Supersyn ?
Pennzoil does not use MoDTC I'm led to believe so.... how many moly's are out there in use ?
I'm thinking now the newer and reportedly darker Havoline uses the same moly as Pennzoil .
Can someone set all this straight ?
Nope, same thing as MoDTC. Some MoDTC's use different sarting materials.
All they're saying is that this MoDTC starts with a MoS5, a moly penta sulfide most likely.
[ March 09, 2004, 04:14 PM: Message edited by: MolaKule ]
I'm thinking now the newer and reportedly darker Havoline uses the same moly as Pennzoil.
Where did you hear this?
It would make sense that Havline and Pennzoil use the same additives. I believe Johnny (Pennzoil guy) told use that pennz uses an Oronite (sp?) additive package.
