The synthetics are coming: Base-oil quality index (BOQI) revisited
Paramount, California
I just saw this very nice article on base-oil demands by API SP/ILSAC GF-6 and GM dexos1 Gen 3. It is an interesting read indeed.
The synthetics are coming by Caitlin Jacobs -- Lubes'n'Greases (PDF version with figures)
The synthetics are coming by Caitlin Jacobs -- Lubes'n'Greases (HTML version without figures)
One of my conclusions in the past was that the base-oil quality is inversely proportional to CCS x Noack for API Groups I - IV, including GTL. For finished 0W-20 oils, I used the following formula as a base-oil quality index (BOQI):
BOQI = 3,500,000 / (CCS x Noack)
(Used for finished 0W-20 oils, CCS measured at -35 °C)
ExxonMobil has introduced a new KV100 = 3.39 cSt PAO base stock with CCS = 623 cP and Noack = 12.5%. Their old KV100 = 4.10 cSt PAO base stock has CCS = 1,430 cP and Noack = 12.4 cP.
These are the base-oil quality indexes for the old and new PAO base stocks:
BOQI (new 3.39 cSt PAO) = 449
BOQI (old 4.10 cSt PAO) = 197
They measured the oxidation times for the two base stocks:
Oxidation time (new 3.39 cSt PAO) = 88 minutes
Oxidation time (old 4.10 cSt PAO) = 41 minutes
The base-oil quality is most closely related to the oxidation time. BOQI for the new PAO base stock is 2.28 times BOQI for the old PAO base stock. The oxidation time for the new PAO base stock is 2.15 times the oxidation time of the old PAO base stock. Therefore, BOQI is indeed directly correlated with the base-oil quality.
In summary if you want to maximize the base-oil quality, you need to minimize both the CCS and Noack. For this reason 0W-16 and 0W-20 oils have higher base-oil quality than thicker oils such as 5W-30. Since the Noack is fixed by the industry and OEM specs, the base-oil quality increases as the oil gets thinner and the CCS decreases. For better deposits control (including on GDI intake valves) and longer OCIs, use the thinnest SAE viscosity grade recommended by your owner's manual and do not use a higher viscosity than recommended.
Good info, thank you.
"Toohey also pointed out that the new PAO performed far better in oxidation stability, scoring 88 minutes in a rotating pressure vessel oxidation test, versus 41 minutes for the conventional PAO. "Esters are a class that show significant promise," he continued. The low-viscosity, lowvolatility esters developed as a part of the project moved even further down the volatility and viscosity scale to KV 100 of 3.14 and volatility of 11.7 percent in one example. However, pour point was only minus 15 C. "There are gives and takes with molecules. Esters will improve solubility but create some other issues," Toohey observed, while emphasizing the need to understand an application to get the right fit."
Longer oil change intervals or better protection from wear with the < 20 wts?
oil blenders ONLY use as much costlier base oils as needed to meet a spec!! usually in the $5 a qt range!!
