Moderators, forgive me for straying from the usual subject format but I have a strange UOA to relate for the general interest and consideration of the BITOG PPM monitors.
Oil: Motorcraft Super Duty HDEO 10W30 API CJ4/SM
Vehicle: '05 F150 5.4L V8, sump capacity 7 qts + 2 qts added for bypass system
Filtration: Primary- P1 (99.7% @ 20um), Racor ABS bypass (99.7% @ 5um)
UOA Duration: 9865 miles, approx. 4K w/o bypass, 6K w/bypass. 2 qts added when bypass installed but no makeup oil otherwise.
Lab: Polaris (SLC)
Notes: Virgin analysis shown first, followed by UOA. The UOA was flagged by Polaris because the UOA stats don't match what they have on file for this oil and are widely divergent from the virgin data. I assure you, all the oil came from the same case of oil, of which I still have two unopened quarts left and one opened. Therein lies the mystery.
Code:
Element Virgin 10K UOA (zero values not listed)
Iron- 1 19
Aluminum- 2 2
Copper- 0 3
Silicon- 0 8
Sodium- 2 1
Potassium- 4 1
Moly- 0 10
Boron- 2 2
Magnesium- 8 73
Calcium- 2642 1829
Phosphorus- 1174 861
Zinc- 1307 985
Viscosity- 11.7 10.7
TAN- NA 2.68
TBN- 7.7 3.72
Oxidation- 9 14
Nitration- 4 11
I would have few complaints about this UOA other than the discrepancy in the specs. Iron is down from 2.5ppm/1k to 1.9ppm/1k. Silicon is up a bit from the last 10K run but still reasonable. TBN is till well up there vs virginand TAN is low, as are oxidation and nitration. Apologies on the formatting. Don't know why it didn't hold from the word doc to the code box. Don't have time to mess with it... it's readable.
For comparison, below is the last set of tests on RP 5W20, that last a 10K run.
Code:
Royal Purple 5W20 SL
Elementals in PPM, 0 values not listed
All Oil Same Batch (2009 vintage)
Oil Capacity- 7 Qts
Test 1 Test 2 Test 3
Test Virgin Used Used
Lab WearCheck WearCheck ANA Labs
Test Date 6/5/09 6/5/09 4/9/11
Vehicle Miles @ Sample NA 18,966 29,290
Oil Miles NA 7,463 10,324
Time in Service. NA 14.5 mo. 22 mo.
Oil Added, Quarts NA 0 1 (@28,520 mi)
Oil Filter NA MC FL820S RP 20-820
Viscosity @ 100C 9.31cSt 8.9cSt 8.93cSt
TBN 13.6 10.0 8.20
MO 170 118 91
MG 1252 1164 915
CA 2524 2280 1708
P 872 825 457
ZN 862 908 1047
P 8.55.1 4
Water
Fuel NA
Copper 0.01 4.4 6
Aluminum 1.3 5.3 5
Nickel 0.5 0.5 1
Iron 3.7 28 25
Lead 1.4 0 0
Sodium 7.1 15 12
Silicon 0 19 2
VI 168 - -
Oxidation NA 27 -
Nitration NA 16 -
Sulfation NA 23 -
Lab: Polaris (SLC)
Code:
Iron- 1 19
Aluminum- 2 2
Copper- 0 3
Silicon- 0 8
Sodium- 2 1
Potassium- 4 1
Moly- 0 10
Boron- 2 2
Magnesium- 8 73
Calcium- 2642 1829
Zinc- 1307 985
TAN- NA 2.68
TBN- 7.7 3.72
Oxidation- 9 14
Nitration- 4 11
Code:
Oil Capacity- 7 Qts
TBN 13.6 10.0 8.20
MO 170 118 91
MG 1252 1164 915
CA 2524 2280 1708
P 872 825 457
ZN 862 908 1047
P 8.55.1 4
Water
Fuel NA
Copper 0.01 4.4 6
Aluminum 1.3 5.3 5
Nickel 0.5 0.5 1
Iron 3.7 28 25
Lead 1.4 0 0
Sodium 7.1 15 12
Silicon 0 19 2
VI 168 - -
Oxidation NA 27 -
Nitration NA 16 -
Sulfation NA 23 -
