Originally Posted By: PeterPolyol
Originally Posted By: Ducked
pre-ignition so damaging, because it is opposing the upward motion of the piston
It is indeed opposing the travel of the piston, but it's the difference between compressing air in a cylinder as it moves upwards vs taking a sledge hammer to a piston, even at TDC.
Hardly. Its compressing a full charge which is doing its normal combustion thing and pushing in the opposite direction.
To describe that as "compressing air" seems a bit disengenuous.
I don't doubt that detonation is a bad thing, but I THINK (I don't have any basis for certainty, and havn't delved into it as deeply as you apparently have) you may be over-stating its general awfulness and under-stating the potential awfulness of progressive combustion due to pre-ignition, when the latter is timed badly.
I base this almost entirely on widely available "classic" descriptions of pre-ignition and detonation, which tend to consider them as separate phenomena with detonation happening exclusively after spark ignition, and with pre-ignition not involving detonation. These classic descriptions nevertheless consider pre-ignition to be much more dangerous. Here's one
http://www.contactmagazine.com/Issue54/EngineBasics.html
Before I'd heard of LSPI I wondered if the classic description was incomplete, since I couldn't see why pre-ignition could'nt cause detonation. It now appears that in LSPI, at least sometimes, it does, and that detonation may happen close to TDC with the piston on the upstroke, worst of both worlds stylee.
I'm not sure to what extent this is a new phenomeno. I suspect the classic description was always incomplete or an oversimplification, but I doubt that it was always completely wrong, which would seem to be implied by saying that pre-ignition almost always causes detonation.
Since detonation is detectable, it would have been detected, and there wouldn't have been so many descriptions of pistons holed by pre-ignition in the abscence of detonation.
As you acknowledge, modern (DI boosted) car engines (which are of only academic interest to me, since I don't expect, or particularly want, to have one) are especially vulnerable to detonation, so its a happening, current thing with terms like "super-knock" to describe the bigger bangs and bills they bring us, but this may not apply to the same extent to all engines past or present.
To get anecdotal, when I bought my current (1986) car I THINK it was detonating intermittantly at idle (sharp taps from somewhere close to the cylinder head) and had probably been doing so for some time. I water decoked it and it stopped doing it. IF detonation was always as damaging as you suggest I doubt I'd still be driving it 7 years later.
Pre-igntion isn't the risk of damage so much as the detonation it can enable. When you try and start an engine with the ignition timing way out or wires crossed and you get a normal spark-initiated "pre-ignition", I mean way way early flame ignition, all it does is bring the cranking engine to a halt for that one stroke; it's much easier on the hardware than detonation.
Well yeh. Its much easier on the hardware because its barely turning over, and then it stops.
This does NOT seem the same as 6000 rpm with one cylinder generating full power DOWN while the other 3, 5, 7, or 11 cylinders and all the rotating mass are pushing UP.
That'll stop too, but probably less temporarily.
